65 Users Online (64 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Dimensioning wrapped walls
Tue, Jan 2, 2007 at 10:22:52 AM | Dimensioning wrapped walls
superelboogie
Im wondering if theres any way to dimension the core of a wall when the gyp is wrapped. i can only dimension to the end of the whole wall so then my dimension is 1/2" off. I have been drawing a detail line to have something to dimension to, but if theres a better way id love to know.
L
Wed, Jan 3, 2007 at 3:51:37 PM | Dimensioning wrapped walls
rkitect
rkitect Avatar
4 Stars: 29 Votes
Have you tried 'tabbing' through all your dimensioning options? When you are dimensions, click your from point and then hover over the gyp at the 'to' point of your dimension. Before clicking to set the point, hit tab until the end of the gyp is highlighted. You may want to turn of Thick Lines (TL) to help see what you're selecting. There is also a drop down box in the options menu of the dimension tool that says something like "Prefer:" with several options. Wall Face is the option you want (I believe it's Wall Center by default)
HTH
Edited on: Wed, Jan 3, 2007 at 4:00:27 PM
Thu, Jan 4, 2007 at 12:28:38 PM | Dimensioning wrapped walls
superelboogie
It will not tab to the end of the stud, it only tabs to the end of the wall, which since it is wrapped is the gyp board.
Thu, Jan 4, 2007 at 3:30:36 PM | Dimensioning wrapped walls
rkitect
rkitect Avatar
4 Stars: 29 Votes
Ah.. I see now.  Yeah, I have no clue on that one.  I tried a couple of different things but never got anything to work.  Sorry :\
Thu, Jan 4, 2007 at 6:20:04 PM | Dimensioning wrapped walls
TomDorner
4.5 Stars: 25 Votes
This has bugged me for years.  A drafting line or reference plane needs to be used to have something to dimension to.  Not very 'Revit like'
Tom
www.reviteer.com   http://twitter.com/Reviteer
Thu, Jan 4, 2007 at 6:56:21 PM | Dimensioning wrapped walls
superelboogie
I REMEBER WHEN YOU COULDNT EVEN DIMENSION TO AN END OF A WALL. NOW YOU CAN BUT NOT TO THE RIGHT LINE. BLAH!
Dimensioning Angular Walls
Mon, Jan 16, 2006 at 6:34:07 PM
Dimensioning from the edges of walls?
Wed, Jan 9, 2008 at 10:23:09 AM
Wall dimensioning
Thu, Jan 19, 2006 at 5:28:48 PM
dimensioning walls with variable thicknesses
Thu, Jan 19, 2006 at 4:58:32 PM
dimensioning oblique walls
Mon, Jan 10, 2005 at 5:06:00 PM
Page generation time: 4.6199
