63 Users Online (62 Members):
Forums >> Revit Building >> Technical Support >> Text & Families / components
25 Posts No Rating |
Is it possible to add text to a 3d component/family in floor plan and elevation and make the text visible once the component has been loaded into a project. It does not work for me because the text is seen as a drafting element it seems. Component loads fine into a project, but without the text. Any trix/ideas?
Have you tried using Model Text? You will have to select the work plane first you wish to attach it to. This is a 3d text format, so you can decrease the depth of the font if it protrudes out too far.
Deb |
The problem with 3d text is that it is model text and will be stay the same size relative to the model, not the drawing.
Have you considered making it into a tag?? Tags are a lot quicker to use and edit when it comes to text than if you had to try and do inside a family. You could also just make an annotation family.
Edited on: Tue, Dec 12, 2006 at 8:43:48 AM
EXCELLENT! Thank you guys, it works beautifullly.
Text in Families |
Mon, Nov 17, 2008 at 10:27:15 AM
Text formatting (bullets & indents) |
Wed, Jun 11, 2008 at 8:49:15 PM
Text in Families |
Fri, Jul 21, 2006 at 11:34:55 AM
Text in Families That DOES NOT Scale?? |
Fri, Jan 16, 2009 at 3:21:38 PM
Copying text & dims from one file to another in 2012 |
Tue, Nov 25, 2014 at 5:22:34 PM
Members: | 1999387 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
