57 Users Online (56 Members):
Forums >> Revit Building >> Technical Support >> Corner Mullioin
3 Posts No Rating |
I need to create a 45 degree angled corner mullion in a curtain wall. I can't find any corner mullions with a rotation parameter and the trapezoid is the wrong shape. The attached screen capture shows what I would like to draw in red.
You can create custom profiled mullions using loaded profiles... Simply create a new profile using the curtain wall mullion profile template, load it in then duplicate one of the existing mullion types and set it to use your loaded profile and adjust as required. HTH.
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer  B. Arch)
3 Posts No Rating |
I don't think you can associate a custom profile with a corner mullion.
Detail over it, or if you need a model, create an in place family.
True you can't nominate it as a corner mullion, but you can still place it and not place a mullion on one of the walls giving the impression of a corner mullion...
Regards,
Chris.
Corner guards to snap to corner of wall |
Tue, May 13, 2014 at 12:18:44 PM
corner windows |
Tue, Jun 3, 2008 at 10:56:06 AM
REAL Corner boards |
Thu, Oct 27, 2005 at 3:51:59 PM
Horiz mullions wont clean up because of angled corner mullion |
Wed, Oct 1, 2014 at 8:43:20 AM
corner mullion storefront [ 1 2 ] |
Sun, Jun 28, 2015 at 5:33:52 PM
15
Members: | 2000395 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
