54 Users Online (53 Members):
Forums >> Revit Building >> Technical Support >> dimensioning angular walls
I have attached a qucik file which contains some angular walls for explanation only. I am having problems trying to dimension the length of the angled walls. The ortho walls dimension fine. The angle between the non ortho walls dimension fine. I simply cannot seem to be able to dimension the length of the angled walls. Can someone give me an idea as how to do so?
Put your arrow on the end of the wall & tab through till you get a dot on that point. It may take a few tabs. when you get the dot right click then go to the other end & repeat.
Macca Sunshine Coast QLD Australia |
Dimensioning Angular Walls |
Mon, Jan 16, 2006 at 6:34:07 PM
showing angular dimensions in degrees seconds etc |
Wed, May 5, 2004 at 7:43:16 AM
Angular surfaces |
Fri, Oct 16, 2009 at 2:23:30 PM
Dimensioning from the edges of walls? |
Wed, Jan 9, 2008 at 10:23:09 AM
ANGULAR DIMENSION TOLERANCE |
Mon, Mar 2, 2015 at 1:00:50 PM
Members: | 1994438 | Objects: | 22882 | Forum Posts: | 152186 | Job Listings: | 3 |
