89 Users Online (87 Members):
Forums >> Revit Building >> Technical Support >> Suspended ceilings in plan view
2 Posts No Rating |
Hello,
How do I make ceilings visible in plan view as an overhead line?
29 Posts No Rating |
raising your view properties cut line would make your ceiling visible in plan view but it would also defeat the purpose of your RCP's
69 Posts No Rating |
Lift the view range to make your ceiling visible. Use the Linework tool to chenge the line style. Set VIEW RANGE back and you should see the selected ceiling lines. It is actually the ceiling not just a line. Was this what you were after?
5 Posts No Rating |
I think Esafin is from Finland. In Finland ceiling areas are marked in plan view with dashdot line which goes the ceiling area from corner to corner. This line should be symbolic line which should be presented only in plan view. I believe that this is quite specific style to mark ceiling areas and it's not included in Revit yet.
Lighting without ceilings |
Mon, May 26, 2008 at 12:56:00 PM
Suspended Ceiling Family |
Thu, May 1, 2014 at 9:04:10 AM
Suspended Lighting |
Fri, Jul 18, 2008 at 3:47:13 PM
Ceilings not showing |
Fri, Aug 12, 2011 at 9:10:52 PM
How to model suspended ceiling in revit 2017 |
Sat, Nov 23, 2019 at 7:58:34 AM
Members: | 1995366 | Objects: | 22882 | Forum Posts: | 152186 | Job Listings: | 3 |
