93 Users Online (92 Members):
Forums >> Revit Building >> Technical Support >> curved walls
8 Posts No Rating |
I am trying to make a curved exterior wall for a circular staircase. If someone could explain to me how that is possible, I would really appreciate it.
admin
with the wall tool drawing a straight line is not the only option... when you click "wall" on the design bar, you have a number of shape options for the wall in the options bar... several of them allow you to draw curved walls... you can also use the pick tool to pick the edge of your curved stair.
Hiroshi Jacobs
The Catholic University of America |
Making a curved wall is the same as drawing a curved line. Click on wall & up the top of the screen you will see 3 options next to chain - line, rectangle, curve. Hit the arrow after these options for a drop down menu with all the options you will need. If you need to make a wall that follows the handrail, you can extrude a wall & add a void to cut the unwanted section out.
Macca Sunshine Coast QLD Australia |
I have repeated a lot of what Hjacobs mentioned. He must be a faster typer.
8 Posts No Rating |
Thanks for both of your help. This is the first time I have used a curved wall in a house.
admin
beat you to it puzzle! ;-)
you're explanation is probably more descriptive than mine so hopefully the two of us made sense...
Hiroshi Jacobs
curved curtian walls |
Mon, Nov 13, 2006 at 6:19:28 AM
curved surface |
Tue, Nov 6, 2018 at 7:03:42 AM
Sloping curved walls? |
Thu, Apr 20, 2006 at 10:09:16 AM
Attaching Curved walls to underside of Curved Stairs |
Wed, Sep 12, 2012 at 12:43:47 PM
Curved Walls with Openings |
Tue, Feb 26, 2013 at 12:35:38 PM
Members: | 1998303 | Objects: | 22885 | Forum Posts: | 152180 | Job Listings: | 3 |
