136 Users Online (135 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> 7600 GT GRAPHICS CARD COLOUR PROB'S IN REVIT
Thu, Sep 28, 2006 at 12:38:46 AM | 7600 GT GRAPHICS CARD COLOUR PROB'S IN REVIT
robert
I have bought a pentium core 2 duo with 4g of ram The graphics card is a gigabyte gef 7600 gt Speed is ok but I am having trouble with the basic colours in revit. colours in windows are ok The monitor is an old CRT Philips 21 BRILLIANCE ” which works fine with revit on an el cheapo card The new machine and graphics card show Red as almost black and that includes the sample colours in the dialog boxes revit has no colour adjustments in i tapparently Has any one got any ideas on how to change these colours?, or should I swap the card back to a fx540 or similar and which one?, they all appear to be pretty old ? i will try to download the latest driver for the video card Thanks and regards Robert. .
Thu, Sep 28, 2006 at 12:53:44 AM | RE: 7600 GT GRAPHICS CARD COLOUR PROB'S IN REVIT
psymon
psymon Avatar
3.5 Stars: 6 Votes
This is no way to change the colours except for the settings under - Settings > Options > Graphics here you can change the selection and alert colours. Otherwise try changing the display driver to open GL. under this same dialog box. Your best option is to contact your hardware sales person or send a query to the graphics card manufacturers. HTH
Thu, Sep 28, 2006 at 1:58:26 AM | RE: 7600 GT GRAPHICS CARD COLOUR PROB'S IN REVIT
robert
thanks for your promt responce. i did follow your instructions i ticked both boxes red still stays black. the selection dialog box also displays the wrong colours. i did try a colour which is available on the selection card but still no luck tied both boxes unticked. still no change thanks for your help. robert
Wed, May 7, 2008 at 7:01:30 PM | 7600 GT GRAPHICS CARD COLOUR PROB'S IN REVIT
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
i would adjust the gamma settings on my card or sell that card and get a quadro or firegl. Sounds like you have a Geforce, thats a gamers gpu and isn't built for high end opengl
Wed, May 7, 2008 at 8:50:56 PM | 7600 GT GRAPHICS CARD COLOUR PROB'S IN REVIT
robert
Thanks for your reply,
this was ambarrissing.
after installing a new quadro graphics card
the we discovered that one of the pins in the cable sockets was bend
one does not expect the monitor to work at all with damage like that.
cheers,
robert
Wed, May 7, 2008 at 9:16:28 PM | alabaster2513
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Quoting alabaster2513 from 2008-05-07 19:01:30
"i would adjust the gamma settings on my card or sell that card and get a quadro or firegl. Sounds like you have a Geforce, thats a gamers gpu and isn't built for high end opengl"
Buying a quadro or Fire GL for revit is complete waste of money.  I've always used gaming cards and never had issues.  This is primarily because gaming card drivers are updated much more frequently then the workstation cards.  Also, revit does not take advantage of high end cards at all, so you would be best spending your money on more RAM and more CPU grunt.  Pick a mid range gaming card and use the latest drivers (preferably without bent pins too Smile)
HTH.
Regards,
Chris.
Wed, May 7, 2008 at 9:38:08 PM | 7600 GT GRAPHICS CARD COLOUR PROB'S IN REVIT
alabaster2513
3.5 Stars: 25 Votes
as an owner of an firegl v3100, v7100, quadro FX 3450, and two geforce 7950 gtx's i am constantly testing capabilities, true revit is processor driven, so we will just have to agree to disagree.
but then again i am also using 3ds max, ADT, photoshop, and piranesi so being 1 dimensional isn't a luxury I can afford.
 best thing i ever did for Revit was RAID 0 and dual Xeon X5355
Wed, May 7, 2008 at 9:41:44 PM | 7600 GT GRAPHICS CARD COLOUR PROB'S IN REVIT
robert
thanks chris,
i am truly converted now.
talking about ram.
revit does not a have a 64 bit system out yet.
with this in mind i thoght of still getting vista 64 bit version
so that at least i can make use of of that lovely ram (got heaps of 150 mb files)
i have been advised however that although i might have a operating system with more than 3 gig of ram
revit itself will not make use of this, which sounds rather strange with a hungry system as revit.
is this true?
the other news or fib is that, revit 2009 has spat the dummy when upgraging large files to 2009
i am now very weary of upgrafing to 2009 (which i now have)
thanks again,
robert
Wed, May 7, 2008 at 10:11:59 PM | 7600 GT GRAPHICS CARD COLOUR PROB'S IN REVIT
alabaster2513
3.5 Stars: 25 Votes
i have been researching 64-bit vista too, i see lots of pros and cons. autodesk claims revit 2009 eventhough it is not 64-bit that its memory allocation feature utilizes the extra RAM i guess. My software retailers inform me though that they nor autodesk offer tech support for vista 64 which i can not confirm. I dream one day of filling all my dimms and harnessing the power of 128 GB of RAM........ *daydreaming*
Wed, May 7, 2008 at 11:04:15 PM | 7600 GT GRAPHICS CARD COLOUR PROB'S IN REVIT
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I'm currently using Revit 2009 with Vista x64 Ultimate and have been for some time.  It all works fine and revit is making use of all the RAM that i've fed it.  They only annoying bug at the moment is that the thumbnails will not display in windows explorer...
I haven't any issues yet with upgrading files, but I haven't had a chance to upgrade some of our larger projects as the client hasn't upgraded yet...  Although they have upgraded one of their 200MB files and it actually fixed issues they were having...
My video card is an 768MB 8800GTX Ultra, but we are also using a few 512MB 6600GT's which run revit fine on dual monitors.
I also run Photoshop CS2, In Design, Adobe Illustrator and the gaming card does okay on these applications.  Not using Max though, no need to Mental Ray in Revit Smile
Regards,
Chris.
Wed, May 7, 2008 at 11:34:38 PM | 7600 GT GRAPHICS CARD COLOUR PROB'S IN REVIT
#11
alabaster2513
3.5 Stars: 25 Votes
i have the same thumbnail issue with vista home premium on my laptop. I think when my workstation goes vista i will try dual RAID 0 and load both 32 and 64 vista ultimate...... cross my fingers and hope nothing blows!
lumion graphics card use
Tue, Dec 2, 2014 at 2:03:22 AM
Revit graphics card?
Thu, Feb 20, 2014 at 12:47:10 PM
Will my graphics card be supported by revit?
Thu, Oct 21, 2010 at 3:43:36 PM
Revit 2015 NVIDIA Graphics Card not recognised on Notebook
Mon, Oct 27, 2014 at 4:45:56 PM
Open GL & Graphics Card
Tue, May 9, 2006 at 7:17:44 PM
Page generation time: 2.3048
