Forums >> Revit Building >> Technical Support >> Interior Elevation Tag
I am trying to figure out how to prevent the view name from being displayed on my plans by the interior elevation tag. I have searched through view properties for the right field to uncheck, I've tried to find the tag in the Imperial Library but it does not seem to be there (i'm sure i am missing something). The previous project I worked in did not display the view names so i know it is possible, but nobody remembers how they were turned off.
Any help will be much appreciated.
Post edited on 2006-09-12 22:34:48
ok, i figured it out.
settings-view tags-elevation tags-show view name
6 Posts No Rating |
THANK YOU for posting this!!! You just saved my bacon from another day of trying to figure this one out!!!
----------------------------------- Newish Revit User :-) |
20 Posts No Rating |
I just found that in the same menu you can change the size of the tag itself, last option at the bottom "dimension" the default is 1/2" Someone might have figured it out somewhere else, but I hadn't seen it yet.
2 Posts No Rating |
How do you do this in Revit 2011?
2 Posts No Rating |
nevermind, figured it out. it's under annotations under the families tab in the project browser. thank you revit for keeping consistent from one version to another.
13 Posts No Rating |
Even after reading this, it took me a while to figure out. So here is what I did, that so far seems to be working. I'm using 2011. Go to the Families area in the browser, and hit the plus to expand it. Go to Elevation Mark Pointer_Circle. Hover over it and right click. Then hit edit. The Family Editor will open. Delete the Name, delete the reference, so that only the 1 is left. Reload it into the project, and say yes to "overwrite existing." Now only the number shows, not the label.
2 Posts No Rating |
I can't find what you are talking about in annotations tab, could you explain further. Thank you
2 Posts No Rating |
I got it, thanks
1 Posts No Rating |
I'm having a similar issue that's driving me crazy. I'm trying to edit the appearance of my exterior elevation tags. I understand how to edit families and have not had problems changing the appearance of other revit tags. However, I can not locate the building elevation tag in order to edit it. I've looked on multiple occasions in the Imperial Library folder as well as under the families tab in the Project Browser. I know I must be missing something because it's just not there ?? Using 2009, but any advice would help. Thanks!
Interior Elevation Tag missing from drop down |
Wed, Aug 18, 2010 at 4:28:45 AM
Modifying Interior Elevation tag |
Thu, Oct 21, 2010 at 8:32:48 AM
Adding a Tail to Interior Elevation Tag |
Fri, Mar 14, 2014 at 1:10:11 PM
Interior Elevation Tags |
Wed, Oct 9, 2013 at 2:23:36 PM
Changing the size of the interior elevation tag |
Wed, Dec 20, 2006 at 12:26:41 PM
Members: | 1998238 | Objects: | 22885 | Forum Posts: | 152179 | Job Listings: | 3 |
