62 Users Online (61 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Text symbols
Tue, Sep 5, 2006 at 3:49:56 PM | Text symbols
JDahl
Wondering if there are any built in short cuts to text in revit similar to Autocad to get particular symbols in the text, as in: Plus/Minus, Diameter,CL, PL, degrees etc... THanks Jeff
Tue, Sep 5, 2006 at 4:37:59 PM | RE: Text symbols
3.5 Stars: 389 Votes
To get special ASCII characters in REVIT just hold down the ALT key while typing the numeric code for the key from your keypad. ie: degree º (ALT 167) diameter Ø (ALT 0216) etc....
Wed, Sep 6, 2006 at 7:05:16 AM | RE: Text symbols
mckdesign
wwhub That is great information. Typing dia. is too long winded. What about m2 to get the 2 to read right. Jason
Tue, Dec 4, 2007 at 7:04:25 PM | Text symbols
twhisker
2 Stars: 4 Votes
The ALT-#### method works great for symbols (degree, diameter, etc..) Does anyone know if there is a way for centerline, property line, or angle??  Seems these are more graphic than they are text.  I want to put them in my abbreviations list that is a schedule.
Revit Architecture 2010
Tue, Nov 17, 2009 at 2:29:46 PM | Text symbols
seniorcad143
1 Stars: 1 Votes
I know this thread is old, but this is what I am looking for.  does anyone have a list of what comes with revit structure 2010.  you would thinkit would.  I really need the PL (plate), CL (centerline), L Cryingangle), +- (plus/minus).
Yeesh - Where is My Cad
Tue, Nov 17, 2009 at 2:36:36 PM | Text symbols
twhisker
2 Stars: 4 Votes
Plus/Minus is Alt 241.  The others are more graphic in nature and cannot be made as a special character.  Rather than keep them in my abbreviationslist, I moved thingslike property line, centerline, etc.... to the symbols legend.  An old thread never hurts cause I've spent 2 years trying to figure out the best way!!
Tue, Nov 17, 2009 at 2:44:14 PM | Text symbols
seniorcad143
1 Stars: 1 Votes
Thanks - well then maybe you can answer my question in Revit Systems Technical Support.  :-)
Wed, Nov 18, 2009 at 7:07:44 AM | Text symbols
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
Where can you find a list of these ACSII characters??
J. Allen Ball
Revit Architecture 2010 Certified Professional
Wed, Nov 18, 2009 at 8:00:51 AM | Text symbols
seniorcad143
1 Stars: 1 Votes
wish I could help you but I am still looking.  Seems each font varies with what they offer as characters.
Wed, Nov 18, 2009 at 10:50:34 AM | Text symbols
twhisker
2 Stars: 4 Votes
Just google ascii character map
http://en.wikipedia.org/wiki/ASCII
http://www.danshort.com/ASCIImap/
http://www.google.com/search?source=ig&hl=en&rlz=1G1GGLQ_ENUS242&q=ascii+character+map&aq=2&oq=ASCII&aqi=g10
Also go to images of the google search as well as web.  Of course there is wikipedia which knows just about anything you need to know.
Wed, Nov 18, 2009 at 11:22:03 AM | Text symbols
#11
seniorcad143
1 Stars: 1 Votes
Now I know I am going to sound stupid - and I looked thru this, but how do I type those in to get the character.  Hold down the alt key while typing the number?
Wed, Nov 18, 2009 at 11:36:46 AM | Text symbols
#12
twhisker
2 Stars: 4 Votes
SI Senor
Wed, Nov 18, 2009 at 12:11:05 PM | Text symbols
#13
seniorcad143
1 Stars: 1 Votes
I think I figured it out - if it says keystroke down at the bottom right of the character map then I can type in a short cut, but if it doesn't then I can't.  I guess the U+2104 for CL in the font simplex doesn't really mean anything I can use, I still have to copy and paste the symbol.
Mon, May 17, 2010 at 6:00:10 PM | Text symbols
#14
rev2010
maybe I should start a new thread for this, I've always copy-paste ASCII characters,
the problem is when I hold alt, type numbers, a new project file opens when I hit the first number, probably caused by customized shortcuts?
Mon, May 17, 2010 at 7:27:10 PM | Text symbols
#15
TomDorner
4.5 Stars: 25 Votes
If you are going to use the ALT codes, you have to hold the ALT key down and use the separate numeric keyboard.  The keys above the letters on you keyboard will not work.
A solution I use is to develop a drafting view in your template that has the common special characters already placed so the user can go to the view and copy/paste.
To get the Windows Character Map, simply go tp Start>Run then type in charmap.  Do this in Windows, not Revit.  Revit simply uses Windows True Type fonts like any other Windows program.
Edited on: Mon, May 17, 2010 at 7:28:17 PM
Tom
www.reviteer.com   http://twitter.com/Reviteer
Text Symbols? [ 1 2 ]
Tue, Apr 28, 2009 at 2:43:34 PM
22
text symbols
Thu, May 31, 2007 at 3:39:19 PM
symbols in text
Tue, Apr 4, 2006 at 11:52:47 AM
The ability of adding text or symbols into line patterns
Thu, Oct 30, 2014 at 2:45:39 AM
Text Styles
Tue, Aug 4, 2009 at 9:59:13 AM
Page generation time: 0.6266
