43 Users Online (42 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Tips & Tricks >> A little SketchUp with your REVIT ?
Search this ThreadSearch this Thread | Page 2 of 3 | << Previous 1 | 2 | 3 Next >>
Tue, Mar 13, 2007 at 12:21:45 AM | A little SketchUp with your REVIT ?
#16
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Very pleased to hear those words !
REVIT ROCKS !
Tue, Mar 13, 2007 at 2:46:39 AM | A little SketchUp with your REVIT ?
#17
coreed
coreed Avatar
4 Stars: 16 Votes
you won't be able to use any of the "by face" commands while creating the mass family, but once it is loaded into a project you should be able to use the "by face" options from the massing tab on loaded mass.
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, Mar 13, 2007 at 3:10:47 PM | A little SketchUp with your REVIT ?
#18
Enginator
5 Stars: 2 Votes
Ok, I imported the attached faucet into a new project. I went to mass and wall by face.   I changed the wall thickness to 1/8" and tried to select a face.  Nothing.
Is this what you meant was supposed to be done?
Tue, Mar 13, 2007 at 8:56:28 PM | A little SketchUp with your REVIT ?
#19
coreed
coreed Avatar
4 Stars: 16 Votes
i start a new Revit project, created a mass, imported you faucet, finished the mass.
i can now use the paint bucket to paint materials on the surfaces, or apply the "by face" options from the Massint tab.
i could have also done this as w new family, but you cannot do any of the above until you load it into a project and place it.
make sure you turn on the thin lines if it is not on, the default lines seem quite thick.
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, Mar 13, 2007 at 9:28:21 PM | A little SketchUp with your REVIT ?
#20
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
AutoCAD 2007 3D is awesome and it does work just like sketchup but with your AutoCAD skills and AutoCAD accuracy.
If you want to learn all the new AutoCAD 2007 3D stuff I've got 32 brand new CADclip videos free for download at http://www.cadclips.com/ACAD2007-3D.htm
Then you can import your autocad solid models into Sketchup and add trees, fencing, benches....airplanes....
See attached SKP file started in AutoCAD 2007 3D then imported into Sketchup and touched up.
Tue, Mar 13, 2007 at 9:45:00 PM | A little SketchUp with your REVIT ?
#21
Enginator
5 Stars: 2 Votes
Ok, I tried that and it works.  I have no idea why, but it works.  It seams you simply create this mass - any mass of any size - and then import the skp file, then finish the mass, and there you have it.  I suppose creating a mass smaller than the one you are importing is the key and import the skp file on top of the created mass so it is not visible.
That's not intuitive at all - but at least it works!
Wed, Mar 14, 2007 at 6:11:41 AM | A little SketchUp with your REVIT ?
#22
coreed
coreed Avatar
4 Stars: 16 Votes
when you create the mass you don't have to create anything inside the mass before you import your file. just import your Sketchup file and finish the mass.
HTH
Edited on: Wed, Mar 14, 2007 at 6:12:12 AM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Mar 14, 2007 at 8:30:22 AM | A little SketchUp with your REVIT ?
#23
Enginator
5 Stars: 2 Votes
LOL! Ya! That came to me as I was going to sleep last night.
 Thanks for the help!!  I'm glad I can put sketchup - or whatever models I find to good use now.
Mon, Apr 2, 2007 at 4:11:35 PM | A little SketchUp with your REVIT ?
#24
DLicata
DLicata Avatar
3.5 Stars: 7 Votes
So you can take models from sketchup, import them into Revit and then assign materials, walls, and details?  When I import my Sketchup model into Revit its all one object and then when I try to explode it at least half the model dissapears.  Sorry if this is a stupid question I'm just very new to Revit but I have alot of experience with Sketchup.
 LHAA
 Licata Hansen Associates Architecture
Reno, NV USA
Mon, Apr 2, 2007 at 8:43:58 PM | A little SketchUp with your REVIT ?
#25
Enginator
5 Stars: 2 Votes
Be sure to read this whole thread.  The way you are currently importing is incorrect.  If you finish the thread and still don't understand, post back.
Tue, Apr 3, 2007 at 12:06:06 AM | A little SketchUp with your REVIT ?
#26
uberchurch
uberchurch Avatar
I am having the same problem as Dlicata above.  I am new to Revit and may be thick but I have read the whole thread and the manual and what ever else I could find and still the same.  The sketchup model comes in as a block that I can do nothing with.  If I try to explode it most of it vanishes.  any help would be great I am pulling my hair out here.
thanks
Tue, Apr 3, 2007 at 12:34:44 AM | A little SketchUp with your REVIT ?
#27
uberchurch
uberchurch Avatar
 ok I just tried it again with somewhat better results. at least the whole model came in but can not do much with it yet.  I keep getting these errors
on import I get:
 "Some ACIS objects could not be imported. To import them, use AutoCAD to convert them into polymesh objects and reimport."
 but the model is all their as far as I can tell at this point.
then when I placed the mass I get:
"Mass contains only mesh geometry, which can’t be used to compute floor area faces, volume, or surface area."
I do not know what i am doing wrong.
thank
Tue, Apr 3, 2007 at 1:14:46 AM | uberchurch
#28
coreed
coreed Avatar
4 Stars: 16 Votes
the above massage dosen't mean that anything is wrong. go ahead and finish the mass and you should be able to use tools such was wall by face to apply Revit components to your mass.
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, Apr 3, 2007 at 8:34:41 AM | A little SketchUp with your REVIT ?
#29
Enginator
5 Stars: 2 Votes
Ok,here's a summary of the steps.
 1. While in the Project, Go to Modeling->Create Mass
2.  Import your sketchup model.
3.  Finish the mass.
 Note that this doesn't work in the Family editor, only the Project editor.
 Use the Paint tool to change the material of the "faces" of your model.
Tue, Apr 3, 2007 at 1:03:12 PM | A little SketchUp with your REVIT ?
#30
DLicata
DLicata Avatar
3.5 Stars: 7 Votes
I followed your steps and it went in great but when I clicked finish mass this popped up "This family instance has too many edges and faces.  Remove unnecessary geometry or split the instance into multiple instances."
 LHAA
Reno, NV USA
Sketchup to Revit
Wed, Aug 26, 2015 at 10:41:27 AM
Tue, Jan 8, 2013 at 12:06:20 PM
SketchUp to Revit
Sun, Mar 22, 2009 at 6:53:33 PM
Sketchup To Revit Problems *Please Help*
Thu, Mar 12, 2009 at 9:21:29 AM
PLEASE HELP! Revit + Sketchup intol Artlantis
Sat, Jun 7, 2014 at 6:26:28 AM
13
Page generation time: 1.3675
