132 Users Online (131 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Rotate View On Sheet
Tue, Jul 18, 2006 at 4:30:39 PM | Rotate View On Sheet
ArchWestCY
4.5 Stars: 7 Votes
Revit makes it easy to rotate a view on the sheet. Your options are: None, 90 Clockwise, and 90 Counterclockwise. I need to rotate a view 32 degrees Counterclockwise. Does anyone know how to edit this feature of Revit to include more rotation options? Live and Learn ArchWestCY
Tue, Jul 18, 2006 at 4:45:51 PM | RE: Rotate View On Sheet
iqlayser
4 Stars: 1 Votes
u can rotate the sheet, but then the print is screwed up.
Tue, Jul 18, 2006 at 4:56:36 PM | RE: Rotate View On Sheet
ArchWestCY
4.5 Stars: 7 Votes
Ya. I noticed that too. This seems like a flaw to me. What's the point of rotating at all if its just going to look messed up. Sorry for the rant. My boss wants to see his stair detail parralell to the bottom of the sheet, how do I accomadate? I am posting this question on my AutoDesk subscription, and will share any results. ArchWestCY
Tue, Jul 18, 2006 at 6:10:16 PM | RE: Rotate View On Sheet
MarieCz
Hmm yea its annoying ay. The only thing i can think of is Export> Image. Export that detail view out of ur project, save it, then import it back into ur project and you should be able to rotate it. Maybe?... I think... ha. I dunno...
I am a-MUSE-d
Tue, Jul 18, 2006 at 6:25:21 PM | RE: Rotate View On Sheet
ArchWestCY
4.5 Stars: 7 Votes
Export Import. Ah such wise advise. If I export it to a .dwg, rotate it, and import it back in it should work. Maybe even the text would be right. Thanks for the idea. This isn't over yet. ArchWestCY
Tue, Jul 18, 2006 at 6:29:54 PM | RE: Rotate View On Sheet
ArchWestCY
4.5 Stars: 7 Votes
This is what Autodesk had to say. As you know; Revit viewports can only be rotated at 90 degrees clockwise or counterclockwise. Since your building needs a rotation other than this, we can only do one of a few things: 1. Rotate the actual building elements in the model (undesirable). 2. Make a new duplicate view and manipulate this view's True North vs Project North. 3. Create a new project for plotting and link in the other Revit project. Steps for option two above: 1. Duplicate the view you need rotated. 2. Open that views properties and switch the option orientation to "True North" 3. Ok out. 4. Click inside the drawing area of this view (to activate it) 5. Choose "Tools -> Project Position and Orientation -> Rotate true north". 6. Set the rotation you want for this view. 7. Any view now set to "True North" will show this orientation in both the view and the sheet. Steps for option three above: 1. Make a new Revit Project. 2. Link in the project containing the views needed, 3. Rotate that file link to the desired angle, 4. Make a sheet in this new project for plotting, 5. Drag that view to a sheet within this project. Please let me know if this helps you to resolve your issue. ArchWestCY
Tue, Jul 18, 2006 at 6:47:52 PM | RE: Rotate View On Sheet
MarieCz
Yea Autodesk's advice is good if you wanted to find true north, but u want to rotate 32 degrees... Either way, useful information to keep in mind. (my way does seem a little quicker though ay...) Hope i helped :D
I am a-MUSE-d
Tue, Jul 18, 2006 at 9:13:46 PM | RE: Rotate View On Sheet
Thread Post Kudo! #8
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Find it hard to believe people don't know this: You can rotate any view an arbitrary amount on a sheet by selecting a the views crop region and rotating it the desired amount. AMAZINGLY THE VIEW CROP REGION REMAINS IN POSITION and the view rotates. HTH.
Tue, Jul 18, 2006 at 10:13:34 PM | RE: Rotate View On Sheet
MarieCz
Oh wow!! Thats crazy!! But it makes sense... now that i know. Yes, Mr Spot, you are the master *bows down and kisses your feet*. lol
I am a-MUSE-d
Wed, Jul 19, 2006 at 4:51:37 AM | RE: Rotate View On Sheet
iqlayser
4 Stars: 1 Votes
Thanks mr spot. now i also know. u`re good keep it up
Golf anyone?????
Wed, Jul 19, 2006 at 7:59:39 AM | RE: Rotate View On Sheet
#11
coreed
coreed Avatar
4 Stars: 16 Votes
are you rotating it in the view or on the sheet once the view is placed ? once placed on a sheet my rotate option is greyed out i can rotate it in the view using the crop region and that is reflected in the sheet but if i place the view on a sheet without rotating and select the crop region, rotate is not available am i missing something?
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Jul 19, 2006 at 12:22:33 PM | RE: Rotate View On Sheet
#12
ArchWestCY
4.5 Stars: 7 Votes
Mr. Spot is a hero. I mean that, you saved my butt. It worked like a charm. Coreed, if the view is already on the sheet you will need to activate the view before you can rotate it. I can't believe that AutoDesk doesn't know this. Doesn't that seem odd. I'm glad to see that subscription is paying off. lol I guess in all fairness I should clue them in. Thanks for the community, and help. ArchWestCY
Mon, Apr 28, 2008 at 3:32:45 PM | Rotate View On Sheet
#13
notagain
notagain Avatar
4 Stars: 1 Votes
now have a question for this solution...how does this affect my linked files?  how does it affecting exporting out to other programs....
I really want this to work...some good things some bad
Tue, Aug 12, 2008 at 9:42:45 AM | Rotate View On Sheet
#14
rquist
I just did what you described by selecting the cropping window starting the rotate command and indicated 90 degrees.
When I pressed enter my drawing session ended as if the enter command was a kill switch
any thoughts.
Mon, Oct 6, 2008 at 11:32:22 AM | Rotate View On Sheet
#15
StephaJ
At one time I was able to select the crop view and rotate my views any degree that I desired as Mr. Spot indicated above.  Something happened to my project file which unrotated one of my floor plan views that I had rotated 90 degrees (but didn't unroate any of the others) and now the option of rotating it is greyed-out.  The rotate option is greyed-out on about 90% of my other drawings as well.....does anybody know what I might have done to the file to make this happen?  ....Mr. Spot??
Rotate view on sheet, but not tag
Wed, Aug 25, 2010 at 9:53:58 PM
How to rotate plan view on sheet ?
Fri, Mar 18, 2005 at 1:06:32 AM
Rotate Drawing on Sheet
Mon, Feb 11, 2008 at 4:28:41 PM
View controls in Sheet window
Sun, Jun 26, 2005 at 5:59:52 PM
Shortcut Key to Rotate 3D View
Wed, Dec 1, 2010 at 4:06:52 PM
Page generation time: 1.4695
