90 Users Online (88 Members):
Forums >> Revit Building >> Technical Support >> Windows in a Garage Door (Help!)
9 Posts No Rating |
I'm trying to edit the default overhead panel door in family editor to have windows cut into it. When I try to make an opening it just tells me that the opening is not cutting anything. Any help would be greatly appreciated. Thank You.
could be a whole host of reasons. you really need to explain more about what you have actually done, the process followed
just download one from the revit city library that already has openings to use as an example
it may shed some light on your problem
HTH
Chances are hte garage door family already has an "opening" which is a Revit object that cuts a wall. What you are trying to add are windows or lights to the garage door family which need to be modeled as Revit objects as the "opening" is what is cutting the wall for the entire garage door family.
Tom
9 Posts No Rating |
tomdimnm you hit the nail on the head thank you!
Garage door? |
Wed, Dec 21, 2005 at 2:59:11 PM
Garage door openers |
Wed, Feb 15, 2017 at 10:18:39 AM
Struggling to find a good wood garage door!!! |
Mon, Apr 6, 2020 at 10:44:52 PM
Garage Door |
Wed, Apr 6, 2005 at 3:45:22 PM
arched opening for overhead garage door |
Fri, May 14, 2004 at 8:45:08 AM
Members: | 1993544 | Objects: | 22881 | Forum Posts: | 152185 | Job Listings: | 3 |
