60 Users Online (59 Members):
Forums >> General Discussion >> Revit Project Management >> Adaptive dimensions
0 Posts No Rating |
Hello everyone,
i turned 90° ccw viewport on the sheet. But dimensions turn with the viewport as well. Now they are upside down. Please how to set dimensions to be visible on the sheet normally?
Thanks,
Matt
You are using the wrong rotate. You are using rotate view on sheet. With that process the entire view, text title are all rotated. Instead, open the view with the crop boundry on. Pick the boundry and rotate it. The model elements will rotate *this view only)but the text and callouts will remain normal to your screen.
0 Posts No Rating |
Yeah, that's it!
Thanks a lot.
Show user created dimensions within Adaptive Component in Sheets (2016) |
Fri, Jul 1, 2016 at 1:55:50 PM
adaptive components |
Fri, Jan 23, 2015 at 7:12:31 AM
Problem with a rectangular section on an adaptive arch |
Tue, Jul 16, 2013 at 7:21:17 PM
Adaptive Component - Flaky Arc |
Tue, Feb 9, 2016 at 1:26:48 PM
annotations on adaptive components? |
Thu, Jan 24, 2013 at 6:21:59 AM
Members: | 2004762 | Objects: | 22897 | Forum Posts: | 152180 | Job Listings: | 3 |
