56 Users Online (55 Members):
Forums >> Revit Building >> Technical Support >> Embeding Curtain wall in a round stacked wall
has anyone every tried embedding a curtainwall into a rounded stacked wall?
i cant seem to get it to work. i broke apart the stack and that didnt work either
True curtain walls are never round or arced because they have to have straight line segments. And in order to do even that, you have to have grid lines to create the segments. This is why your stacked wall will not work.
You say rounded, not round. Define your wall end to end as a CW type with enough grids to define a nice arc.
I'm sorry, I should have specified, it's a straight curtainwall going into the rounded wall.
I solved it by just using a door opening to make an opening in the rounded wall and then I put the curtainwall in the opening
Can't Put Curtain Wall Inside Stacked Wall??????? Help Needed |
Thu, Jan 24, 2013 at 8:06:06 PM
embed curtain not embeding |
Fri, Apr 1, 2016 at 4:42:33 PM
Curtian wall within another curtain wall |
Wed, Jan 21, 2009 at 4:30:03 PM
Stacked Wall w/ Curtain wall within? |
Wed, Aug 11, 2010 at 4:09:30 PM
Wraping Stacked Walls at Curtain Walls |
Wed, Dec 24, 2008 at 1:40:26 PM
Members: | 1994711 | Objects: | 22882 | Forum Posts: | 152181 | Job Listings: | 3 |
