78 Users Online (77 Members):
Forums >> Revit Building >> Technical Support >> Convert wall from thick to think at corner fillet-arc
0 Posts No Rating |
Hello there,
Do you know how to make it convert from wall 220mm to 110mm at corner using fillet-arc? Please see the picture for example.
Sorry, there is no way for revit to do this automatically. You could use two different walls at that curve, an inner wall and an outer wall with appropriate inner or outer only layers.
0 Posts No Rating |
Thank you for your respond. I don't get it. Can you show the picture how it work?
Regards,
Bogumil
You don't say what your wall is, is it multi-layerd or sigle material?
What I had suggested was to define 2 new walls, one with the exterior material and one with the interior material. Then create those two walls in yor location and join them to your other walls.
0 Posts No Rating |
Make the first arch with Finish Face Exterior and copy it down to create the transition.
0 Posts No Rating |
I got it now. Thank you for your explanation, WWHub. Thank for your picture with example. It is brillant Surfingjp :-)
fillet arc on stairs |
Fri, Oct 28, 2011 at 12:39:35 PM
Fillet arc not working on baluster panel extrusion |
Wed, Oct 26, 2011 at 5:56:34 AM
Stacked wall problem - corners do not fillet. |
Wed, Jul 16, 2008 at 11:40:39 AM
3D Fillet/Chamfer |
Thu, Sep 2, 2010 at 5:31:42 PM
Fillet to wall |
Sat, Apr 16, 2011 at 9:14:46 PM
Members: | 1991840 | Objects: | 22879 | Forum Posts: | 152186 | Job Listings: | 3 |
