73 Users Online (72 Members):
Forums >> Revit Systems >> Technical Support >> Revit Elevation Marker rotating
Hi,
I have a plan, it is on a sheet and then I rotated the view on the sheet
Is there a way to rotate the elevation tag as it is reading side ways? I have attached an image for reference.
It needs to be like the section tag.
This is probebly a simple fix but I have no idea what to do with it.
Kind Regards,
Britt
I think you probably used the wrong rotation. Don't rotate the view on the sheet if you want the text to be 'normal' to the sheet layout. Instead, open the view, turn on the view boundry, select that and rotate the view. All model elements will rotate and all text will remain 'normal' to the screen.
Split a an elevation marker up for mulitple sheets |
Tue, Oct 4, 2016 at 2:29:34 PM
Adding a reference elevation to an existing elevation marker? |
Wed, Sep 17, 2014 at 7:57:46 AM
ELEVATION MARKER |
Thu, Sep 10, 2009 at 2:55:39 PM
Importing a New Elevation Marker |
Mon, Dec 19, 2011 at 12:01:54 PM
If your elevation markers on plan disappear. |
Fri, Mar 4, 2016 at 3:40:45 PM
Members: | 2000728 | Objects: | 22886 | Forum Posts: | 152182 | Job Listings: | 3 |
