118 Users Online (117 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Print range.
Thu, Jan 26, 2017 at 8:25:55 AM | Print range.
lukdab
Suddenly Revit started ignoring titleblocks on sheets.
It looks like the center of the output is the center of a sheet wherever titleblock is placed.
Thu, Jan 26, 2017 at 8:50:13 AM | Print range.
3.5 Stars: 390 Votes
Please include relevant information.   You can be printing to a printer or to a PDF or ????  You don't give us a clue!
Printing problems are often the result of failure to update your printer drivers - not a revit issue.
Thu, Jan 26, 2017 at 9:01:57 AM | Print range.
lukdab
Doesn't matter if it's a printer or pdf. It happened during few hours. In the morning it worked as usual. Now it doesn't. We work on one model and it's happening on all of the computers.
Question is:
is there some option that declares if the titleblock define printing range?
Thu, Jan 26, 2017 at 10:16:36 AM | Print range.
You are in control of the printing.
If all of your computers are having problems, it's your printing device.
Fri, Jan 27, 2017 at 9:09:01 AM | Print range.
lukdab
Some sheets works properly.
Sheets in other project work properly.
I have titleblock 1600x420 mm, when I change its size to A3 the print range is somewhere else than the titleblock. Moving the titleblock up or down moves the print range alsoup or down. But moving the titleblock right or left doesn't effect on print range.
Fri, Jan 27, 2017 at 10:52:51 AM | Print range.
You do understand that you have to select the correct papaer size in your printer setup?
Fri, Jan 27, 2017 at 7:02:15 PM | Print range.
mansell5
3.5 Stars: 4 Votes
1600w x 420h is a very odd size for a title block or drawing sheet.
are these sizes correct?
Mon, Jan 30, 2017 at 12:29:02 AM | Print range.
zakazai
could you please try a "ZA" in the sheet, for zoom all.
may be there are small point or line in the sheet away from title block, when you select sheet that also try to include as sheet boundary, then you will loose title block.
then try a preview with fit to page option as well. then only try sheet printing direct.
Please inform if you got solution
Mon, Jan 30, 2017 at 1:57:07 PM | Print range.
thinkpositive
5 Stars: 7 Votes
Maybe some of your view on the sheet has a crop boundary out of the titleblock. Click on the views in your sheet and look for their crop boundaries. Sometimes this fixes printing issues.
Tue, Jan 31, 2017 at 2:45:30 AM | Print range.
lukdab
Yes. There was something out of sheet. So thanks.
But when I wanted to print some part of a view on A3 I just moved the titleblock where I wanted without croppin view or something and it worked as I wish. So I guess I can't do that with few views on a sheet at once.
Print Range Locked
Tue, Oct 28, 2008 at 2:11:30 PM
PRINT RANGE SETS BY PARAMETERS
Wed, Feb 23, 2011 at 12:56:06 PM
crop option for printing in sheet
Tue, Apr 1, 2008 at 4:57:41 PM
Electrical shows up in plan view, but will not print.. Help!
Mon, Jul 21, 2014 at 3:04:35 PM
how I print 2 or more sheets in the same print sheet?
Mon, Aug 31, 2009 at 9:36:48 AM
Page generation time: 0.5269
