63 Users Online (62 Members):
Forums >> Revit Building >> Technical Support >> Missing Wall Tags
I'm using Revit 2017
I'm getting some weird behavior and was wondering if anyone has seen this type of behavior or know what might be causing it. On multiple different projects, when I print to pdf the wall tags (I have created) do not show up on the created pdf. After creating the pdf, I go back and check the sheet in the model and sure enough, they show up. I try to recreate the anomaly (print to pdf again) under the same circumstances and the wall tags show up in the pdf. This has behavior has resulted in creating construction documents without wall tags (which is not good). I don’t turn off/hide wall tags really ever and again, after creating the pdf I have gone right back to the sheet to check and the wall tags are all visible.
Not sure if this is a glitch with Revit, my wall tag, something else I am inadvertently doing. Any help or ideas would be greatly appreciated.
Just for kicks, I have also attached my wall tag if there is anyone brainy enough to want to try to dissect it to see if they think it might be the culprit (but again it does seem to work for the most part).
Thanks in advance!
Switch your pdf driver - try cute pdf - its free.
MISSING elevation tags |
Mon, Sep 17, 2018 at 10:55:17 AM
Section Tags missing (again) |
Wed, Aug 26, 2009 at 10:50:38 AM
room tags and floors |
Thu, Jan 26, 2006 at 3:54:41 AM
elavation tags missing |
Sun, Sep 13, 2009 at 7:58:17 PM
WALL TAGS - VERY BASIC QUESTION |
Fri, Apr 25, 2008 at 11:19:34 AM
Members: | 1999329 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
