27 Users Online (26 Members):
Forums >> Revit Structure >> Technical Support >> MATERIAL NOT TRANSPARENT.
3 Posts No Rating |
RECENTLY I CREATED A BASE PLATE WITH GROUT BED. I USED THE MATERIAL "Grout - Non Shrink - 5ksi"
and set the transparency to 100. in a 3D view it looks like it should (Transparent) but when i go to a section view the grout is not trasparent.
any ideas why this is?
Materials in section view are shown according to the material graphics tab settings settings. Not the same as the render settings.
3 Posts No Rating |
I did set the transparency in the graphics tab under shading. i also set it in the family as well. but nothing
That setting is for the face of the material in non-rendered views. A section view only uses the CUT PATTERN ! You said it is a section view - that cuts the material, it does not show it in elevation.
Creating transparent material such as 3FORM |
Wed, Aug 26, 2009 at 8:09:06 AM
MAKING DEMOLISHED OBJECTS TRANSPARENT |
Tue, Mar 12, 2013 at 2:02:34 PM
TRANSPARENT MATERIAL SHOWING IN 3D |
Wed, Mar 6, 2013 at 3:16:18 AM
Render transparent material |
Mon, Jan 4, 2010 at 7:32:55 AM
Transparent Materials |
Sat, Sep 6, 2008 at 6:52:36 AM
Members: | 1994403 | Objects: | 22882 | Forum Posts: | 152185 | Job Listings: | 3 |
