Forums >> Revit Building >> Technical Support >> Quirk Quries
Wed, May 10, 2006 at 8:27:36 AM | Quirk Quries
SteveB
3.5 Stars: 5 Votes
[1] If I set dimensions to "entire walls" why are there many 0" dimensions? It's not that there is some small item there, if I set the units to 128ths it's still zero. There is no underlay on. Any way around it?
[2] is there a way to do a "repeat command" like in Autocad? Much wasted time & cliks without it.
[3] A way to set "tag categories" to default to "free end". more cliks and sore wrists.
Wed, May 10, 2006 at 10:56:32 AM | RE: Quirk Quries
JDahl
This is an option with new release of revit (we are using revit structure 3, I think the new building release is 9)
Wed, May 10, 2006 at 10:59:40 AM | RE: Quirk Quries
SteveB
3.5 Stars: 5 Votes
I have revit 9, where is the option?
Wed, May 10, 2006 at 11:20:51 AM | RE: Quirk Quries
JDahl
Well If the tags are already on the drawing, it looks like your stuck, have to highlight them and click free end, but when you click tag, right up beside where it says leader on the top menu bar, there is a pull down that says attached or free end... if you set that to free end when you start tagging, they are all free ends.
Wed, May 10, 2006 at 11:30:49 AM | RE: Quirk Quries
JDahl
You are correct though, next time you click tag, you still have to click free end again. Sorry, in structures 2 this was not even an option, for some tags anyway, I missed your key word "default" Revit should default to the last used setting for alot of commands and it doesn't.
2011 quirk, with cursor/property fields
Thu, Jul 15, 2010 at 1:44:24 AM
Area Boundary Lines - R2015
Thu, Apr 14, 2016 at 2:22:27 PM
Roof Error - HELP
Thu, Jun 9, 2011 at 4:48:08 PM
Double cutting families
Mon, Jun 7, 2010 at 3:31:03 PM
How to pivot about centroid of model?
Fri, Aug 24, 2007 at 9:02:55 AM
Page generation time: 4.1271
