62 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Soffit wall & ceiling joins
Fri, May 5, 2006 at 3:15:08 PM | Soffit wall & ceiling joins
rkitect
rkitect Avatar
4 Stars: 29 Votes
Trying to get a soffit type detail. I set this up using a Soffit Hgt level and based my walls and ceilling on that level. I want the gypboard to wrap all the way around.. what do I do? This is what I'm getting: http://gibsonhouse.dyndns.org/famfoto/main.php?g2_view=core.ShowItem&g2_itemId=565 This is what I want: http://gibsonhouse.dyndns.org/famfoto/main.php?g2_view=core.ShowItem&g2_itemId=567 Thanks!
Mon, May 8, 2006 at 4:00:56 AM | RE: Soffit wall & ceiling joins
eldados
eldados Avatar
4.5 Stars: 8 Votes
THE ONLY WAY I CAN THINK OFF RIGHT NOW (AFTER A LONG DAY..) IS YOU USE SWEEP FOR YOUR PLASTER, DON'T THINK YOU CAN JOIN THEM OTHERWISE...
Integrator
KarelCAD
Mon, May 8, 2006 at 7:56:24 AM | RE: Soffit wall & ceiling joins
latemore
latemore Avatar
3 Stars: 2 Votes
not sure if this would help, and might be too basic. i have started adopting mr spot's and others idea of separating roof/wall/floor layers, so you obtain better control. this reflects mr spot's and eldados's assertion that we should be using revit as the buildings are built, ie as separate elements. i do not know how you make the ceiling/wall pieces of plasterboard merge though.
Mon, May 8, 2006 at 8:21:42 AM | RE: Soffit wall & ceiling joins
rkitect
rkitect Avatar
4 Stars: 29 Votes
I try to build things the way they are supposed to be built, this way my details are built as I model. However, when you can't get things to join the way they are supposed to this method becomes difficult. I'm thinking I may just have to build an in-place family to handle situations like this. Any ideas are welcome. Thanks for your time guys/gals.
Soffit face wall join issue
Wed, Feb 23, 2011 at 4:13:14 PM
Ceiling soffit?
Thu, Jul 13, 2006 at 7:11:21 PM
Interior ceiling soffit?
Fri, Jul 27, 2007 at 6:59:37 PM
Ceiling Soffits
Tue, Mar 9, 2010 at 4:01:29 PM
Attaching a wall to a ceiling and a roof, can it be done?
Tue, Sep 22, 2009 at 3:15:43 AM
Page generation time: 0.8411
