87 Users Online (86 Members):
Forums >> Revit Building >> Technical Support >> Creating depth of field with elevations
Ok I am trying to duplicate what you did in your tutorial with the masses. I seems like a simple solution to the problem, but somehow I am messing it up. I have the mass in front front of my building elements that I want to get screeened. But i am getting 0 sreening. What am I doing wrong.
Is the mass in the correct place and the correct size? If so, reduce the transparancy of the material or check that masses are turned on in the view.
Edited on: Fri, Apr 17, 2009 at 10:51:50 AM
I think so. If I have it turned on in plan it screens like it is supposed to but in elevations in does not do anything. It is interesting that on the floor plan it will not screen doors and door swings. Any suggetions
148 Posts No Rating |
Hey Chris (or anybody) Where is your blog? I'd like to see the demo you did on toning down elements in elevations that are beyond.
Ian Shafer
Principal Consultant
True North S&F Consultants |
never mind ... I found it on your website. BRILLIANT! Thanks Chris. You always have the tips I need. Autodesk needs to tap into your brain. :o)
Ian Shafer
Creating depth in elevations. Why not....................? |
Tue, Mar 11, 2008 at 1:29:46 PM
Creating a calculated field that I can use in other schedules/tags RAC2009 |
Fri, Jul 24, 2009 at 1:16:39 PM
linked file visability and cut depth [ 1 2 ] |
Thu, Jul 13, 2017 at 3:23:18 AM
16
Depth Perception in Elevations |
Wed, Jan 9, 2013 at 9:58:56 AM
13
shaded elevations in CD's |
Thu, Nov 1, 2007 at 2:54:17 PM
Members: | 1998850 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
