57 Users Online (56 Members):
Forums >> Community >> Newbies >> Need Basic Template
Hi,
I wants to start a new project but I haven't got any 'Project Template' and I didnt download when I installed programme, where can I get basic revit project template?
Ali
hi Ali,
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles/Revit-Templates-and-families-not-installed.html
The link above shows you how to install the templates from your installer.
Hope this helps.
Kind Regards,
Shatner86
"Try not to become a man of success, but rather to become a man of value"
-Albert Einstein |
If you installed the library, then you installed a template(s). Your problem is that the template location is not set and probably none of your other library locations. These are all set under the Revit R dropdown. You can browse for the template location when you goto that setting.
REVIT Architecture 2009 Basic Architectural Convention question [ 1 2 ] |
Tue, Oct 21, 2008 at 8:19:58 AM
15
Buy Architectural Template from Last parametrics |
Sat, Jan 25, 2020 at 3:59:59 AM
Cannot get the Mechanical-Default_Metric.rte template to load |
Sat, Jun 9, 2012 at 2:30:21 AM
ARCHITECTURAL TEMPLATE VS C0NSTRUCTION TEMPLATE |
Thu, Sep 27, 2007 at 5:19:28 PM
Template Update |
Sat, Jun 25, 2016 at 6:01:29 PM
Members: | 1994958 | Objects: | 22882 | Forum Posts: | 152181 | Job Listings: | 3 |
