82 Users Online (81 Members):
Forums >> Revit Building >> Technical Support >> Schedule Visual accuracy using placeholder sheets
Hi all, I've been using placeholder sheets in my schedules to list out consultant drawings that will be in the set after the actual architectural drawings. In the referenced images, all sheets except Architectural are placeholders. I put together a new field so that they are first organized by displine order (E), then by displine (C), and finally by sheet order, (D). Adding a header to the Discipline field allowed me to break the grid and have a displine name at each change.
Does anyone know if there's any way to control the text size and type in those intermediate headers? Or location?
under the appearance tab you have the option to change both the header and body text size and properties
although those intermediate text lines are considered "headers" within the Sorting/Grouping tab, the "Body" text style controls their appearance, and there doesn't seem to be an override option.
Hmm well then the other option is to make each disipline a seperate schedule and then just line them up by placing them on your sheet.
Schedules/Legends on Placeholder sheets |
Fri, Dec 6, 2013 at 5:22:48 AM
Filtering placeholder sheets by discipline in a sheet list |
Thu, Jun 23, 2011 at 12:27:04 PM
revision schedule different sheets |
Wed, Feb 18, 2009 at 3:03:51 AM
shared coordinate accuracy |
Wed, Feb 6, 2013 at 8:50:17 AM
Door Schedule Fit on Two Sheets |
Wed, May 22, 2013 at 12:35:17 PM
Members: | 2004435 | Objects: | 22887 | Forum Posts: | 152178 | Job Listings: | 3 |
