52 Users Online (51 Members):
Forums >> Revit Building >> Technical Support >> Combine Discipline
Hi everyone!
I've M&E drawing, split into categories as Electric, Plumbing, HVAC .How i could combine all categories in one Drawing (by name Combine)in project!
By split into "categories" do you mean they are in seperate revit files as seperate models. If so just link the revit models into one main model using shared coordiantes.
Yes i split file revit into "Electric ,Plumbing, HVAC file" .Now, i want combine all into one file" combine name"include (electric,Plumbing,Hvac).Can you guide do it.where's it in categories?
Edited on: Fri, Jun 17, 2016 at 7:42:37 AM
Typically we would never do this because these are best kept seperate but linked together to show what is needed in each discipline.
After you Link in the REVIT models select one, and click 'Bind Link'. That turns it into a group. Then select the group and ungroup it and now you have everything living in the same file.
Yes..but how i can copy system electric,pipe system,duct system into a combine drawing?because when inserted link revit ,all system wouldn't copy into new project.
where are my walls?? |
Thu, Apr 2, 2009 at 10:51:30 PM
Sub Discipline under Views? |
Fri, Apr 17, 2009 at 2:21:21 PM
Drawing Index order |
Mon, Apr 20, 2009 at 5:26:40 PM
Can't find Sub-Discipline in Properties |
Mon, Jan 27, 2014 at 5:24:22 AM
Controlling Display setting per Discipline |
Fri, Feb 17, 2012 at 12:33:04 PM
Members: | 2000169 | Objects: | 22886 | Forum Posts: | 152180 | Job Listings: | 3 |
