161 Users Online (160 Members):
Forums >> Revit Systems >> Technical Support >> Void form issues once again. Few question
4 Posts No Rating |
Would I be correct that you can only make a void form in the family itself and not inside the project, right?
For instance if I am in my project, make an in place mass, then try to make a void form from the same create mass button on the mass I just created in the project, that it will not work... so it has to be done only inside the family itself? No way around that I take it?
Also i can create an in place solid in my project but cannot creat an in place void form. I take it that is the way it is?
I browsed through some of the questions on void forms in here but never see the above questions answered so much.
Any help on this would be super appreciated.
Max.
Incorrect. You can create in-place void families but you have to tell them what you want them to cut.
4 Posts No Rating |
But it has to be done inside families, you can't do it in the project itself.. right?
NO! As I said, you can create in-place void families. In-place families are only created in the project. You can create an in-place void family, say in the wall category, and have that cut a wall. A wall is only create in the project. It is system level and never a loaded family.
void form and cuttng void form |
Fri, Jul 9, 2010 at 12:39:02 PM
VOID form will NOT work! [ 1 2 ] |
Mon, Jan 30, 2012 at 3:00:24 PM
22
Void form for sink |
Fri, Jul 17, 2009 at 12:43:42 PM
VOID FORM says there is no geometry to cut.... [ 1 2 ] |
Wed, Dec 17, 2008 at 12:52:27 PM
19
Face-Based Family for Void Form? |
Wed, May 18, 2011 at 10:19:38 AM
Members: | 1995120 | Objects: | 22882 | Forum Posts: | 152183 | Job Listings: | 3 |
