104 Users Online (103 Members):
Forums >> Revit Building >> Technical Support >> masking linework behind components
4 Posts No Rating |
Hello all... I am a revit newbie with more zeal for the program than experience. I am working on detail drawings, where I am adding components such as a cmu bond beam or roof drain to wall/roof sections. I can get the components in, no problem, but the "medium" to "fine" detail of the wall structure shows through. How can I mask or "cut out" these lines?
Your help is much appreciated!
Tzzy
what i have been doing on my wall sections lately, is putting a filled region that is filled with a solid white hatch overtop of the entire region i want to draw over. that masks out all the stud lines no matter the detail level. i then simply draw in the level of detail i want to show. it creates a bit of a re-draw, however it allows me to control my section line weights much better. this may not be the best solution, but it seems to be working for me.
4 Posts No Rating |
Thanks, gdoorn... I will try the filled region approach...
4 Posts No Rating |
The filled region approach does work well... however, the linework that is associated with the filled region, ie. the outline of the filled region, still shows... any suggestions?
Thanks again... tzzy
35 Posts No Rating |
When you create your filled region you could use one of two options -
1/ Use invisible lines to create the bounded area of the filled region
2/ Use the pick tool instead of the pencil (draw) tool to creatre the filled region bounded area
Hope this helps
----------------------------------- AutoCAD & Revit TAFE teacher from regional Australia |
You should explore using the "linework" tool. It is the icon that looks like an old fashioned fountain pen. The linework tool over-rides the display of any model line that is diplayed. You can choose "invisable" or one of the other linetypes in your project. To get the line back to it's normal category display choose "by category" and it will be reset.
HTH
Tom
Masking Regions in Symbols not working |
Thu, May 7, 2009 at 5:47:00 PM
2D 3D Model Masking |
Mon, Aug 24, 2009 at 5:26:53 PM
Can you save linework? |
Tue, Aug 12, 2008 at 7:37:07 PM
Revit 2010 Masking Regions |
Mon, Nov 30, 2009 at 4:42:34 PM
Detail Components with Demo Objects |
Tue, Dec 30, 2008 at 4:34:29 PM
Members: | 1998218 | Objects: | 22885 | Forum Posts: | 152179 | Job Listings: | 3 |
