71 Users Online (70 Members):
Forums >> Revit Building >> Technical Support >> Baluster Top Offset Issue
I created a guardrail family to represent an existing condition pipe rail we are working with. The railing is made of welded 2.5" dia pipe for the balusters and the top rail and the bottom rail. In Revit, when the baluster top offset is set to 0", the top of the baluster pipe is shown ending as it hits the top rail. If I change it to anything over 0" (1/2" for example) it jumps above the top of the top rail. How do I get the top of the baluster to land in the middle of the top rail as though it were welded to it? See image.
Thank you!
I've had a bit of a play around with this issue, as i've had the same problem plenty of times.
A solution that i've come up with today, is to embed a very small dia pipe inside the TOP RAIL and then change the balusters to host top to the embeded rail instead of the proper top rail. You may need to experiement a little bit with the actual height of the embeded rail to get the appearance that you are seeking.
In the example image, you can see the small dia rail inside the top rail.
sorry, it appears that the image did not want to attach properly.
Nice work-around - thanks for sharing.
Great idea, thanks. Wish there was a sophisticated Revit fix, but like so many other workarounds, this is probably the best bet.
Top rail offset |
Wed, Jun 21, 2017 at 11:14:51 AM
Glass Panel Baluster Issue |
Wed, Nov 2, 2011 at 4:13:25 PM
12
2015 use baluster per tread on stair (with no top rail?) |
Thu, Sep 3, 2015 at 4:50:57 PM
custom baluster with decorative piece not staying equal 2019 |
Thu, Jun 14, 2018 at 1:54:47 PM
Newbie help: how to intersect railing with baluster |
Wed, Mar 25, 2009 at 4:26:53 AM
Members: | 1991525 | Objects: | 22879 | Forum Posts: | 152184 | Job Listings: | 3 |
