45 Users Online (44 Members):
Forums >> Revit Structure >> Technical Support >> justification problems creating general notes.
3 Posts No Rating |
ive been setting up a general notes sheet in revit but it seem every time i set up a text block the way i like it and zoom in or out the justification keep changing. not sure what to do.
Hey etrod1968,
Need a little more information, but I think i have encountered the issue you have mentioned below.
How sparing are your text boxes? I find that when i make the boxes as small as possible when I zoom out or edit they then change by adding another line.
Prehaps make the boxes a little more generous will solve the problem like it did for me.
If this is not the issue please tell me more about it and I'll try and help you out.
Kind Regards,
Shatner86
"Try not to become a man of success, but rather to become a man of value"
-Albert Einstein |
This is only a problem if you are using hard returns and tabs to fomat the text. We all wish Revit had better text formatting but it doesn't. Use the built in numbering/bullets and only use hard returns at paragraph/number breaks. If you want an extra line between numbered items, then use two columns of text - one for the text and one for the numbers. This is a pain but still easier than fixing line breaks.
creating General Notes (best practices/ efficient methods) 2017 |
Fri, Nov 17, 2017 at 4:37:25 PM
Importing General Notes |
Wed, Feb 9, 2011 at 8:08:29 PM
Typing General Notes |
Mon, Sep 20, 2010 at 1:32:39 PM
General notes & vent calcs |
Tue, Oct 11, 2005 at 6:15:04 PM
Adding a General Notes section to our model spashscreen |
Thu, Jun 13, 2013 at 10:03:02 AM
Members: | 1994422 | Objects: | 22882 | Forum Posts: | 152185 | Job Listings: | 3 |
