181 Users Online (180 Members):
Forums >> Revit Building >> Technical Support >> Family Types Issue
I have created a custom window family with several types but all the types end up being the same when loaded into a project, and dependant on which type was active in the family editor last. Can anyone explain why this is happening / how to fix it?
I'm pretty new to (semi-)parametric family creation so it may well be something stupid that I've missed.
I have attached the relevant family, and the misbehaving parameter is the height.
Using Revit architecture 2015
Thanks
Something must be corrupted in that family.
I started a new family from the 2015 template with just the opening and it functions correctly so I know the template and Revit is not the issue. You may have done something in your process to corrupt this system parameter but I don't see it.
Start again and as you develope the family, test it often.
Thanks, WWHub, I'll give it another shot
Family types - conditional statement |
Mon, Apr 18, 2011 at 3:59:50 PM
Purge Command - possible to purge family types accidentally? |
Tue, Aug 20, 2013 at 12:01:08 PM
Family types problem. |
Tue, Apr 21, 2009 at 10:00:20 AM
Major issue in Family Default Type setting |
Thu, Nov 23, 2017 at 8:48:09 AM
Family re-load |
Tue, Dec 29, 2009 at 7:39:53 AM
Members: | 1998494 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
