65 Users Online (68 Members):
Forums >> Revit Structure >> Technical Support >> Beam System is not resetting after I edit the boundary.
0 Posts No Rating |
I place a beam system, all works well. However when I edit the boundary the beams never adjust. Yes I hit "Reset System" after I have shifted the boundary then the large green check.
I even began a test project and it did the same thing after I edited the boundary.
None of the joists in the beam system have moved, nor have they become unpinned.
I should note that it will magically work 1 times out of 30 or more. Is this a bug perhaps?
0 Posts No Rating |
Here is the test project. The dashed beam system is the edited boundary. The joists did not conform to the new boundary after "Reset System" was clicked.
Always post what Revit you are trying to talk about.
0 Posts No Rating |
Revit 2015
I am doing structural.
This is controlled by the bar joist’s start/end offset in properties. It’s a ‘instance’ parameter, so you need select all your bar joists, or change the parameter to ‘type’ in the family, or use non-structural walls.
0 Posts No Rating |
I'm not completely following...Are you saying that the beam system is tied to the wall somehow? Becuase when I do a beam system with no walls below, editing boundary works flawlessly. The ones with a (structural) wall below does not.
If I have to manually select the joists and change their Start and End Offsets, then what's the point of beam systems?
Is your wall structural and in the same place as your 'beam'?
How does Revit know what supports these elements?
Beam System Tags |
Wed, Feb 27, 2013 at 12:55:27 AM
Adding a beam system issue |
Sun, Jun 15, 2014 at 2:58:10 PM
beam system |
Thu, Oct 15, 2015 at 7:32:17 AM
Beam system height VS. Beam height error |
Fri, Jan 22, 2016 at 4:31:20 PM
structural beam system irregularity |
Fri, Dec 19, 2008 at 3:03:10 PM
Members: | 1993529 | Objects: | 22881 | Forum Posts: | 152185 | Job Listings: | 3 |
