113 Users Online (112 Members):
Forums >> Revit Building >> Technical Support >> diagonal to straight wall dimension.
Is it possible to make this dimension line - as the pictures attached.
If so, please let me know how
With aligned dimensions, first get the perpendicular wall (easier that way) and then click on the angled wall intersection point. If that point doesn’t highlight, tab a few times until it does – zoom in to see.
With linear dims, just click on the intersection points.
Thanks,
But what if i dont want the intersection point.
I want just a random point on the diagonal line....
Cannot be done without a help of model/detail line or a ref plane.
OK that what i thought...
it is a bit absurd that it cand be done.....
What good is the dimension if it doesn't go to anything? Doesn't make any sense!
Revit Dimension Straight Leader Line with Controllable Node at Elbow |
Thu, Jul 12, 2018 at 12:32:47 PM
Curtain wall mullion - corner lines diagonal? |
Wed, Dec 9, 2015 at 7:31:31 AM
Diagonal End of Wall - Void + Cut Geometry not working |
Fri, Aug 30, 2013 at 3:25:08 AM
How do you create diagonal openings in walls (as viewed in plan view) |
Mon, Jun 13, 2016 at 11:22:13 AM
Activate Dimension |
Tue, Dec 13, 2011 at 12:53:44 PM
Members: | 2000869 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
