79 Users Online (78 Members):
Forums >> Revit Building >> Technical Support >> Custom Type of Parameter in Family Editor
0 Posts No Rating |
Hello,
I had a question about families in the families editor. When the family types dialog box is open and then you add a parameter, in the parameter properties dialog box there are options in the "Type Of Parameter" pulldown. Is there any way to add custom made options. I know that if the discipline is changed other options will populate but i am looking to create a custom type of parameter. Would anyone know how to pursue this action?
Thank you
There are only 2 parameter choices here - 'instance' and 'type'. You are confusing this with system parameters based on the family category.
If you start with the correct category template to begin with, you should see the associated parameters for that category. For those families where you start with a generic template, you need to set the family category and parameters by clicking on the upper right icon in the properties box while in the family editor.
If you mean the parameter data settings then what you see is what you get. This is all system level and you have to fit under those options. Other is always available.
Edited on: Thu, May 14, 2015 at 3:22:24 PM
Edited on: Thu, May 14, 2015 at 3:23:01 PM
excluding a type in the family type parameter |
Thu, Mar 20, 2008 at 3:38:32 AM
adding mass in family editor or in place family creation |
Thu, Nov 23, 2006 at 9:52:52 AM
Family-Type Parameter deleted |
Mon, Jun 3, 2013 at 5:04:18 PM
<Family Type> parameter can't be controlled by formula. What else can we do? [ 1 2 ] |
Tue, Aug 27, 2013 at 3:53:53 AM
29
Family Type driven length parameter help |
Thu, May 1, 2014 at 3:08:42 PM
Members: | 1992063 | Objects: | 22879 | Forum Posts: | 152183 | Job Listings: | 3 |
