148 Users Online (147 Members):
Forums >> Revit Structure >> Technical Support >> beam system
These beam systems are killin me, though not any worse than most things on Revit that you've never done before.
So I have a beam and a wall and I want to use them as supports for a beam system. Somehow I cannot choose them as supports and so the beam system is at the level associated with the plan view and it's flat. I've been stuck on this for a while now and I would almost rather just place the beams manually, but I know this has to work.
Make sure your walls are structural and check 3D option in beam system properties.
Beam system height VS. Beam height error |
Fri, Jan 22, 2016 at 4:31:20 PM
Adding a beam system issue |
Sun, Jun 15, 2014 at 2:58:10 PM
Beam System Tag |
Fri, Aug 14, 2009 at 3:09:33 AM
Schdule of Beam System |
Tue, Jan 4, 2011 at 5:45:12 AM
beam system |
Thu, Oct 15, 2015 at 7:32:17 AM
Members: | 1977032 | Objects: | 22860 | Forum Posts: | 152166 | Job Listings: | 3 |
