90 Users Online (89 Members):
Forums >> Revit Systems >> Technical Support >> Lineweights For System Filters
Hello,
I have created filters for the piping systems in my revit project. I am trying to figure out a way to adjust all the different pipe system line weights, so i created filters for the pipes of each pipe system. I was able to change the lineweights for each pipe filter to show the way i would like to in my view. Although when i edit the filters, the pipe line weights that ive edited are only view specific. Is there any way i can edit the lineweights for the filters project wide so i dont have to go to each view and edit the filters for the different pipe systems?
Thanks
Do you know how to use view filters/
I think WWHub meant "View Templates".
Yes i do know i how to use the view filters. Although i wanted to see if i can edit the line weights for my filters in my filters tab project wide so i dont have to go into each view and edit each view filter individually
Hello,
Ok, i see where this is going. Totally dimissed the view templates. Thank you @ WWHUB and @Gyvven
I'm getting too old .... I did mean VIEW TEMPLATES! Thanks Gywen
Controlling the Lineweights of Window Subcategories using Filters |
Fri, Jun 27, 2014 at 7:21:24 PM
phase filters and lineweights |
Fri, May 22, 2009 at 3:15:11 PM
Lineweights Issue |
Thu, Nov 17, 2005 at 6:05:35 PM
Lineweights in Elevations |
Thu, Jun 26, 2014 at 3:47:40 PM
Lineweights Question |
Wed, Aug 3, 2005 at 4:03:11 PM
Members: | 1991992 | Objects: | 22879 | Forum Posts: | 152183 | Job Listings: | 3 |
