170 Users Online (169 Members):
Forums >> Revit Structure >> Technical Support >> schedule glitch.
I cannot get the schedule to report the thickness of the element, even though it is clearly in the properties of the element.
Is this a stock family or one you created?
If it is one you created, is that parameter shared?
Its a regular footing in Revit. Also, the schedule is picking up an existing footing that I would like excluded from the schedule.
You will have to tell us what family. I don't have any problems. Perhaps you have something filtering them out.
Change your foundation schedule properties - phase filter - to show new.
thanks for the phase filter answer!
OK it is a regular rectangular footing. I duplicated it to make it longer and wider and thicker in the edit type box...I named it GB-1 for the type mark so that would show up in the schedule in the desired way. Here's a screen shot...
You have modified that family. Thickness is a type variable - not instance.
OK I can see that, so what do I do? There is no footing with the right thickenss that I need. Do I try and work the parameters so that they show up like they should?
Also there is now a footing in the schedule that is nowhere in my model.
This is part of the power of Revit. You can have type or instance variables. For type changes, click on the footing then click on edit type - duplicate - give it a proper name and then change the type variable to what you need for that type.
BTW - Read up on parameters. They are more than a name. You added your 'Width" which was not the same shared parameter as the Width in the type definition. Keep learning.
Revit 2013 Stair Glitch |
Mon, Dec 17, 2012 at 11:16:11 AM
Stair Rail Glitch |
Thu, May 7, 2015 at 7:35:59 PM
glitch in schedule import |
Tue, Oct 8, 2013 at 12:41:14 PM
Dimension Glitch? |
Tue, Nov 17, 2015 at 3:02:41 PM
Revit 2010 Glitch? |
Fri, May 8, 2009 at 10:36:47 AM
Members: | 1991046 | Objects: | 22877 | Forum Posts: | 152184 | Job Listings: | 3 |
