85 Users Online (84 Members):
Forums >> Revit Building >> Technical Support >> Tag crown molding (wall sweeps)
Am I crazy or can you not tag any sort of wall sweep object? If so, what tag should I be using? None of the out of the box tags worked, so I made a simple Generic Object tag and that didn't work either.
High quality modern Revit furniture!
www.therevitcollection.com
The Revit Collection: High Quality Revit Families | Revit Furniture |
I don't see any normal tags but you can add a project parameter to wall sweeps then maybe you can tag it. You can use a material tag... which you can also modify to read a project parameter assigned to materials.
Hope those ideas will help.
Yeah.. modifying the material tag was the best solution I came up with as well. Just wanted to make sure I wasn't missing something by not being able to tag it "normally". I'll try project parameter too but seems like that will get too complicated for the average Revit user in the office.
Thanks WW
How to add crown molding header above a window |
Thu, Feb 26, 2015 at 12:57:30 PM
Crown Molding Help |
Thu, Feb 1, 2007 at 7:22:54 AM
crown molding |
Tue, Jun 13, 2006 at 11:44:39 PM
Crown Molding - Cabinetry |
Wed, Jun 29, 2011 at 5:30:33 PM
Crown Molding on Narrow Walls |
Tue, Dec 13, 2016 at 6:12:36 AM
Members: | 1998251 | Objects: | 22885 | Forum Posts: | 152179 | Job Listings: | 3 |
