88 Users Online (87 Members):
Forums >> Revit Building >> Technical Support >> Wall wraping in windows and structural columns
Hi Everyone
i am facing very annoying problem in revit. i have a multilayered wall in revit and i insert a window in it tried wrapping and it worked but as soon as i insert the structural column inside the same wall and join the wrapping disappeares.
Please see the attachment and suggest.
Regards
I cannot recreate your problem, it works ok here. Have you modified the window and column families in any way, or are they untouched OOTB? Can you upload your file or at least post some screen shots of your wall properties and assembly?
Please see the attached revit 2014 file.
Thanks in advance
Edited on: Sun, Feb 1, 2015 at 11:58:21 PM
Edited on: Mon, Feb 2, 2015 at 12:02:03 AM
Edited on: Mon, Feb 2, 2015 at 12:03:23 AM
For some reason the file is not being attached.. so i uploaded it on dropbox please use the link to see the file :
https://www.dropbox.com/s/r8u43nebe7tmu6n/Project5.rvt?dl=0
Edited on: Mon, Feb 2, 2015 at 12:08:44 AM
when the column is totaly crossing the wall it works fine BUT when its partially crossing the wall this problem occur.
This condition doesn’t play nice. I’ve come up with 3 possible solutions – see pictures and enclosed file. Maybe someone else will have some other/better ideas, …sorry.
Thanks a lot our problem was solved with the third option.
spliting the wall from CL of column.
Regards
Windows and structural columns |
Thu, Jun 8, 2006 at 2:22:59 AM
structural wall VS structural columns |
Tue, Apr 26, 2016 at 3:49:39 PM
Structural Columns not cutting walls |
Mon, Jan 4, 2016 at 4:13:25 PM
Concrete Columns and Beams cuts through wall... |
Mon, Feb 4, 2013 at 8:10:15 AM
Structural columns |
Mon, Jan 16, 2012 at 8:37:32 AM
Members: | 1991785 | Objects: | 22879 | Forum Posts: | 152186 | Job Listings: | 3 |
