166 Users Online (165 Members):
Forums >> Revit Building >> Technical Support >> Unable to open Revit Model .Error -This family instance has too many edges.
Hello,
I just ran into this problem wherein I am unable to open this revit model which I saved last night.I had linked a Skp file into it and then did some modeling on it.Its showing this error "This family instance has too many edges. Remove unnecessary geometry or split the instance into multiple instances." .The revit model doesnt open up so how can I edit or delete the elements with high no. of edges.
Link to the file.
https://www.dropbox.com/s/9nfgchzfr3kyds7/Revit%20Model.rvt?dl=0
There is no way to edit the skp file in Revit anyway.
If the file is linked, then move it to where revit can't find it.
I did renamed the skp file and the revit model opened up.Thanks for your suggestion.
error message, unable to open revit file |
Thu, Nov 6, 2008 at 9:12:12 AM
Error: Revit was unable to render the view due to an unknown error. |
Mon, Apr 28, 2014 at 3:32:17 AM
updating a revit arch model error (REVIT 12) |
Fri, Mar 1, 2013 at 4:06:42 PM
"Unable to write to..." Error Message |
Mon, Sep 30, 2013 at 7:34:37 AM
The file is already open for editing by another user. You will unable to save an |
Sun, Apr 29, 2012 at 9:17:33 AM
Members: | 1998675 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
