74 Users Online (73 Members):
Forums >> Revit Building >> Technical Support >> Translucent Existing Phase after Rendering
0 Posts No Rating |
Hi there,
I use Revit Architecture 2014. I am trying to figure out how to make an Existing Phase to look translucent/transparent after Rendering.I tried to change it in Phasing/Graphic Overrides/Material of Existing phase, but existing phase appears to be just solid grey after rendering. The reason I am trying to do this is to make existing buildings appear like a 'background'. For example, if there is a street of terraced houses and I want to create a new construction between 2 existing terraced houses, I want the new construction to be looking normal, but 2 houses from the both sides would be for example white translucent/transparent or grey translucent/transparent after rendering. So the new construction 'stands out'. It is simply for presentation purposes. Is it even possible to do this in phasing settings?
Thank you.
0 Posts No Rating |
And additional question would be: Buildings marked as Existing Phase don't show shadows. Is there a way how to change it?
Thank you
Walls set as existing not showing up in existing phase settings. |
Sat, Aug 4, 2012 at 11:21:58 AM
Rendering problems with existing phase |
Tue, Sep 19, 2006 at 2:24:36 PM
New Construction phase cuts Existing Phase |
Tue, Aug 9, 2011 at 12:21:57 PM
Site and phasing troubles |
Mon, Apr 19, 2010 at 5:03:04 PM
Existing Phase Surface Patterns visibility |
Tue, Nov 14, 2006 at 6:37:24 PM
Members: | 1998825 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
