129 Users Online (128 Members):
Forums >> Revit Building >> Technical Support >> Room Tag Area (Actual vs. Programmed Area
I am working on a tag that will show the "actual" area of the room and then display the "Program Area" which is a parameter that I have created in the room data. It was not a shared parameter and it was not working, so i went ahead and created a shared parameter for the room tag family, but that parameter will not show up in the room data. Not sure how i can get the tag to talk to the room data.
In the image I attached the "?" should be the "Program Area"
2 Posts No Rating |
You need to also load the shared parameter into the file. Manage- Shared Parameters- Browse for your parameter file- select the parameter and click OK
When you add it to the project, you have to add it to the rooms category.
Total area of rooms in a department vs. programmed area for that department |
Wed, Jul 3, 2013 at 11:12:20 AM
Room tags with area - area not showing up! |
Thu, Aug 16, 2007 at 6:54:26 PM
Editing a room tag |
Thu, Oct 12, 2017 at 3:17:41 PM
Room Tag vs Area tag |
Tue, Aug 18, 2009 at 1:10:59 PM
Tagging 2 rooms with the same tag/area |
Wed, Nov 20, 2013 at 8:11:44 PM
Members: | 1989670 | Objects: | 22877 | Forum Posts: | 152180 | Job Listings: | 3 |
