156 Users Online (155 Members):
Forums >> Revit Building >> Technical Support >> Section line disappears from plan when section view is placed on same sheet
0 Posts No Rating |
Hello,
I am a first-time poster and using Revit Architecture 2013. I'm having an issue placing a detail section on a sheet next to the plan it was created in. As soon as I place the view, the section line disappears. However, if I place the view on a different sheet, it does not disappear.
Three images attached:
-Before placing view
-After placing view on same sheet (section line disappears)
-After placing view on different sheet (section line shows just fine)
I'm stumped, please let me know if you hav any idea how I can get that section line to stay. Thanks!
All three of your updates are installed - right????
If you don't know then look under the question mark drop down - about.
0 Posts No Rating |
It says Update Release 3 so yes I believe so...
I just checked it out and I have no problems with this in my 2013.
SOmething else going on here. It may be a video card issue - How does it print?
0 Posts No Rating |
I just revisited this problem again today. I'm convinced that it's a problem with some property of the sheet. It is currently on a "DA" sheet and it actually works fine if I change the sheet prefix to anything that doesn't start with D. For example, if I change the "DA" to "AD" it's fine. Are there any sheet properties that are somehow controlled by the sheet name??
If not, I'll just figure out a way to fake it :/
There is no sheet property that would do this but we do occassionaly see corrupted sheet. Delete that sheet and create a new one and place the views on that. Audit your file.
Section Line in Extends Beyond Plan (2009) |
Sun, Sep 21, 2008 at 11:30:18 AM
Wall Section won't show in both plan and building section |
Wed, Jan 29, 2014 at 6:52:25 AM
Section markers disappear in plan when cropping the section view. |
Tue, Nov 27, 2007 at 3:33:58 PM
Section cut disappears when I change the view range in plan view. |
Tue, Oct 28, 2008 at 3:50:07 PM
Section tag missing on plan but section still exists |
Tue, Nov 22, 2016 at 2:58:15 PM
Members: | 1990731 | Objects: | 22877 | Forum Posts: | 152180 | Job Listings: | 3 |
