93 Users Online (92 Members):
Forums >> Revit Building >> Technical Support >> How do I add a countertop to the Base Cabinet - Corner Unit Angled?
7 Posts No Rating |
The only countertop available in the library is the item: CounterTop 24" depth, but it will not fit the Base Cabinet's angled shape. The countertop from the Revit library only fits rectangular spacs. What am I supposed to do here?
Thanks, to whomever replies!
Post edited on 2006-03-04 03:08:59
You could make a new casework family or make an in-place counter by going to Create>pick casework>name>solid extrusion. Use the level as work plan and make counter top. Make sure you set the properties to match the existing top.
Have a look in the tutorials on extrusions. i have just completed a shop fitout mainly using in-place families.
Hope this helps
Macca Sunshine Coast QLD Australia |
28 Posts No Rating |
i edited the original counter top which is just a L-shape and drew the required angle in.
all i did was measure the angle tht needed covering and drew it in, but i then offset this line by say 20mm which is the overhang
26 Posts No Rating |
After dickin' with a number of custom counter tops and bar tops I'm ready to try Mr. Spot's suggestion. I believe it was Spot that said to make countertops thin floors. The floor tool and editor are easy to use, offset from the Level in question, make 1 1/2" thick, follow/offset from your cabinetry, select a material, and you're on to the next issue.
36 Posts No Rating |
"After dickin' with a number of custom counter tops and bar tops I'm ready to try Mr. Spot's suggestion. I believe it was Spot that said to make countertops thin floors. The floor tool and editor are easy to use, offset from the Level in question, make 1 1/2" thick, follow/offset from your cabinetry, select a material, and you're on to the next issue."
That is a pretty creative solution.
Using that meathod, or using actual counter top families what is the best way to add sinks to counters. Is here a way to create a sink famile that autonaticly cut the counter top it is placed into?
Post edited on 2006-03-30 06:59:06
Help with Parametric Depth on Corner Cabinet |
Fri, Oct 26, 2012 at 2:57:39 PM
Drop in range and casework |
Mon, Feb 14, 2011 at 7:21:18 AM
angled corner joint - how to lock angled corners |
Thu, Jul 18, 2013 at 5:10:11 AM
11
Add "grouting" between a flat wide base and angled narrow top |
Sat, Mar 13, 2010 at 7:40:32 AM
Student just starting |
Wed, Feb 25, 2009 at 4:38:26 PM
Members: | 1987054 | Objects: | 22874 | Forum Posts: | 152184 | Job Listings: | 3 |
