58 Users Online (57 Members):
Forums >> Revit Building >> Technical Support >> Window panels that adds up! :3
Is there a way to have a window family with constant window panel width that adds up?
Example, I have a window family that has 2 panels with a width of 600mm
Can I create a parameter that can make my window family from 2 panels to 6 panels?
If it can be possibe, please tell me how.
Thank you!!!
Parameters are just text/numbers unless they actually control something. To do what you want, you will need a family that has multiple instances of "panels" and that is controlled by a parameter. I doubt that your window is built like this but i can be modified or you can create one that does this. There are many examples of families with arrayed sub-elements in them. They are not easy to build and if you are not experienced, I suggest you learn the fundamentals first and look for a different family.
What families do i need to search for? I am eager to learn this. I'm experimenting this kind of families but from what i have learned so far i still can't make it. I know it can be done since some families in revit like the curtain walls, you can adjust its number of panels.
Thank you for the reply :3
If you want something that acts similar to a curtain wall you need to look into parametric arrays
Placing window at intersection of 2 precast concrete panels |
Sat, Jan 5, 2008 at 7:57:00 AM
revit family that adds parts as you adjust it |
Tue, May 3, 2016 at 6:32:22 AM
Curtain wall Panels Pre-delevoped Adding a Door or Window? |
Fri, Jan 20, 2012 at 7:55:06 AM
Turning certain curtain panels into spandrel panels |
Tue, Dec 3, 2013 at 1:59:47 PM
Door with window panels that can be turned on and off |
Thu, Jul 3, 2014 at 1:22:04 AM
Members: | 1994737 | Objects: | 22882 | Forum Posts: | 152181 | Job Listings: | 3 |
