58 Users Online (57 Members):
Forums >> Revit Building >> Technical Support >> level not show up on plans
Can any one help me I copied a multiple number of levels on the elevations and they are not showing up on the floor plans. The levels exisy cause I could copy things to it but they do not show up on the Project browser.
Arc
I had this some time ago. The could find no way round it. I had to delete the levels and draw a level in elevation using the new level command. Then copy and paste objects between the levels. Then they appear in project browser. Not sure if anyone knows of another way with "copied" levels.
After copying the levels in elevation, go to View>New>Floor Plan. Select the Levels you want to create Floor Plans for. These created Floor Plans will now show up in the Project Browser.
In your elevation, levels show as blue when they have a plan asociated with them, otherwise as black.
you will need to create your plans to show up...
view tab on the left-->Floor Plan... and pick your floor plans
Floor Plans need to show Ceiling on them in Revit 2011 |
Thu, Aug 26, 2010 at 12:40:35 PM
Problem with Levels and Plans |
Thu, Sep 6, 2012 at 12:25:55 PM
Structural Slab Levels on Plans? |
Fri, Dec 22, 2006 at 9:42:09 AM
Can Railings show in Ceiling Plans? |
Tue, Jun 23, 2009 at 1:56:36 PM
Walls show up on Second Level plan |
Wed, Dec 19, 2018 at 8:39:24 AM
Members: | 1998887 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
