80 Users Online (79 Members):
Forums >> Revit Building >> Technical Support >> join between wall and floor issue
hi,
i am geting a problem when joining between wall and floor in revit and i don't know how to make it right. the problem is when i join wall and floor which have same placed edge, it automatically turn same placed edge into thin line while it should be wide line (see attched image below)
currently, i have to draw manually a wide line right to this place.
thanks for reading and any help will be appreciate!
p/s:
this issue occurs at same placed edge only (draw floor by pick wall - extend to wall core)
sorry for my bad english
Edited on: Thu, Apr 24, 2014 at 10:03:41 AM
Post an image for the "Edit Assembly" of both of those walls.
I believe your problem is layer priority. You can read about that in your Help:
About Applying a Function to a Layer of a Compound Structure
Revit 2015 join wall to underside of floor and ceiling issue |
Wed, Mar 2, 2016 at 2:59:03 PM
Join wall/floor |
Thu, Jul 2, 2009 at 7:07:41 AM
Column Join issue |
Wed, Oct 11, 2017 at 10:10:15 PM
JOIN FLOOR AND WALL |
Tue, Feb 2, 2016 at 4:58:26 AM
Soffit face wall join issue |
Wed, Feb 23, 2011 at 4:13:14 PM
Members: | 1990880 | Objects: | 22877 | Forum Posts: | 152184 | Job Listings: | 3 |
