89 Users Online (88 Members):
Forums >> General Discussion >> Revit Project Management >> Need Help Adding Trim Boards
0 Posts No Rating |
Hello, I am currently working on a cabin project in my drafting class on Revit 2014. My teacher has requested that I add trim boards on the corners of my exterior walls and I have been unable to figure out how to do so... If anyone could possibly link me a tutorial or anything would be extremely helpful, thank you in advance.
You could create an in-place extrusion for the corners or depending on how many you need you could just create a parametric family an load it into your project.
You can also use the wall sweep - vertical. That could be an 'L' shaped profile but this can be tricky on which wall you place it from.
corner trim |
Fri, Apr 2, 2004 at 2:17:39 PM
Skirting boards |
Tue, Dec 15, 2015 at 3:36:54 AM
Adding exterior trim to window |
Tue, Nov 10, 2009 at 8:27:34 AM
Adding Material to Roof trim? RAC 2009 |
Mon, May 12, 2008 at 1:57:10 PM
Applying skirting boards to walls |
Fri, May 20, 2011 at 7:18:42 AM
Members: | 1986916 | Objects: | 22874 | Forum Posts: | 152182 | Job Listings: | 3 |
