76 Users Online (75 Members):
Forums >> Revit Building >> Technical Support >> copy paste to a linked file
23 Posts No Rating |
i am workin on revit 2014,
i am working on a 3 story hospital building and i made the ceiling plan with all the light fixtures on the same file .. now the problem is that our manager decided to seperate the electrical work than the architectural . So we opened a new electrical template and linked our original file to it . THEN we tried to copy and paste all the light fixtures to the same place but they cant find the hosts !! I dont know why....
anyone can help , Do i have to do the lighting of the whole hospital again from scratch ?
If the light fixtures are hosted (and they are) then you need to own the host.That is what copy monitor is for....so you have a copy of an element in your file.
I tried copy monitor ... most of the objects can be copied but the ceiling which is my host can not be copied or monitored !! Why ??
I don't use systems so I was not fully aware that you can't copy monitor a ceiling. You will have to place your own. It might be the generic one that is there on startup.... it has no properties other than being a plane that Revit identifies as a ceiling. Or you can copy the ceilings from the other file and paste them in.
Copy and Paste Elements from Linked Models is Easy ! |
Thu, Jul 4, 2019 at 4:23:18 PM
Copy & Paste into Teamwork file |
Tue, Nov 11, 2008 at 8:47:27 AM
Revit MEP 2010 copy/paste lighting fixtures |
Sun, Feb 16, 2014 at 12:46:34 AM
Saving a copy of a Revit Masterplan file with linked buildings to a new location |
Thu, Jun 20, 2013 at 12:57:34 PM
Copy and Paste |
Fri, Mar 6, 2009 at 5:31:33 PM
Members: | 1994935 | Objects: | 22882 | Forum Posts: | 152182 | Job Listings: | 3 |
