161 Users Online (160 Members):
Forums >> Revit Building >> Technical Support >> ARCHITECTURAL COLUMN ISSUE
11 Posts No Rating |
Hi again Guys,
Please see attached image and check what problem I'm having with my columns. Because I didn't want my column's cut pattern (solid) to assume my wall's cut pattern (crosshatch), I draw walls every after columns. Is that the best practice? or drawing a long wall and then adding the columns at certain intervals? but what can I do so that the column's cut pattern do not assume the wall's cut pattern?
Thanks.
Use a structural column instead of architectural.
Thanks WWHub. My plans now are OK.
'til next time. :-)
Column Join issue |
Wed, Oct 11, 2017 at 10:10:15 PM
"Tag by category" of Architectural Column in Plan |
Thu, Apr 16, 2009 at 2:45:20 PM
Architectural Vs. Structural Linking |
Tue, Feb 19, 2019 at 10:42:28 PM
Architectural column accepting wall properties but not sweeps |
Thu, Jun 12, 2008 at 2:03:06 PM
Best way of creating column casings |
Fri, Aug 19, 2011 at 2:17:12 AM
Members: | 1995506 | Objects: | 22885 | Forum Posts: | 152175 | Job Listings: | 3 |
