53 Users Online (52 Members):
Forums >> Revit Building >> Technical Support >> Lighting tags move when "emergency option turned on/off
I am building a electrical library using Revit 2013. I noticed this problem while creating lighting fixtures with an emergency filled region associated with a yes/no parameter. Once the fixture is placed within my project and its tagged with a "Type Mark" tag. If I select or deselect the instance parameter for emergency hatch, the type mark tag moves to a different location than where I had placed it. I cannot figure out what is causing the lighting fixture to act this way. I have created different types of fixtures as well as hosted and nonhosted. Not all of my families are behaving this way though. I have also noticed it on other families that I created with "clearances" yes/no parameters.
Tags attach typically to the center of a family and that may be changing when you switch this.
Am I dreaming or did I read something about being able to set the tag location now in the family 2014?
WWHub - any news on setting the tag location in 2014?
I don't think I've seen a tag move by just changing the family type (which basically turns a fill pattern on).
However if the emergency fill pattern is a 'nested' family with a different base point from the main family it may just jump based on what WW states. ie: Keep the two base point the same. Basepoint is defined at the intersection of two reference planes that 'define origin' as properties.
Edited on: Mon, Apr 28, 2014 at 6:07:00 PM
Help. I forgot how I "turned off" the room tags. |
Tue, Oct 8, 2013 at 7:18:18 AM
11
tags tags tags |
Tue, Mar 20, 2012 at 12:10:23 PM
Looking for Emergency Vehicles and plants |
Sat, May 16, 2009 at 3:09:23 PM
Tags linked in more than one view |
Fri, Feb 27, 2009 at 6:21:47 AM
revit 2012 - display option background disappeared and turned black |
Mon, Jun 25, 2012 at 4:48:13 PM
Members: | 1999820 | Objects: | 22885 | Forum Posts: | 152181 | Job Listings: | 3 |
